vcLinkNode
Link node is a node added to component's structure and is mainly used to define joints and other mechanisms of movement in a component.
Parent: vcNode
Referenced by: vcComponent.createLink(), vcLinkJoint.ChildNode
DofvcDofRGets the degree-of-freedom (DOF) object that defines the joint properties of the node and its mechanism of movement. If joint type is fixed, Dof will be None.
JointTypevcJointTypeRWGets or sets the node's joint type
Jointslist[vcLinkJoint]RGets a list of link joints associated with this link node. Returns joints where this link is the vcLinkJoint.ChildNode
OffsetvcMatrixExpressionPropertyR
Access expression value via vcMatrixExpressionProperty
Gets the expression property that, when evaluated, returns the node's offset.
createJointvcLinkJointvcLinkJointType typeCreates a new joint associated with this link.
type (vcLinkJointType): The type of joint to create.
vcLinkJoint: The newly created joint.
Example: Listen Joint Value Update Events
""" This example shows how to continuously check an event value in a while loop.
DISCLAIMER: it's not often performance-wise recommended to rely on
high interval based logic if not necessary.
import vcCore as vc
async def OnRun():
  comp = vc.getComponent()
  x_link = comp.findNode("X_link")
  while True:
    await x_link.OnNodeTransform.wait()    # any vcEvent found in the API can be waited.
    if x_link.Dof.VALUE > 100:
      await delay(1) # on position, do some task
